It is currently Tue Jul 15, 2025 5:12 pm
PostPosted: Mon Oct 16, 2006 4:30 am
I am looking for a few hard to find sizes of drill bits. In a perfect world a high quality forstner bit would be perfect.. but I am striking out so any flat bottomed bit would probably work.
37/64"
19/32"
39/64"
If you know where I could get some that would be great.
Thanks.
PostPosted: Mon Oct 16, 2006 4:36 am
Look for center cut end mills if you can't find drill bits. MSC or any machinst supply with carry both the drill bit and the mill cutter
john hall
PostPosted: Mon Oct 16, 2006 11:51 am
I ended up finding some brad point bits at www.preferred-drillbits.com
I was hoping for forstners, but these will work ok.
PostPosted: Mon Oct 16, 2006 1:12 pm
Brock, I bet you could buy some slightly oversized forstners and have a machine shop turn them down to the size needed and resharpen them.
PostPosted: Mon Oct 16, 2006 1:30 pm
You might try these guys they claim to have all sizes and also custom make drill bits to order.
http://www.advantage-drillbits.com/
